http://www.ford-focus.cz/forum/viewtopi ... 69#p415169
Bezzatkova palivova nadrz
- Dzefer
Re: Palivova nadrz
yuray, asi je nejaky virus vo vzduchu, pri poslednom tankovani to robilo aj mne
- yuray
Re: Palivova nadrz
dzefer, pri Easy Fuel™ sa podla navodu neodporuca tankovat z opacnej strany. Mozes tym vraj poskodit ten ich slavny system...
Evidentne je nas s tymto problemom viac, ja sa uz idem objednat na prvu garancku tak som zvedavy co na to povedia. Uz som na ten "vytok" zvyknuty, pri kazdom tankovani kontrolujem aka je mlaka pod autom...
- yuray
Re: Palivova nadrz
vyberam z diskusie na britskom webe:
08 2.0 Fuel overflows at first automatic shut off - MikeTorque (Thu 3 Sep 09 00:21):
I refuel the fuel tank until the first automatic shut off of the filling station nozzle and leave it at that, I don't try putting more fuel in. I then notice there is diesel fuel coming out of the fuel overflow pipe underneath the rear of the car, about 0.5 litre or so which leaves a right mess on the forecourt floor to be cleared up, not to mention the wasted fuel.
It's occurs every time I fill up to the first automatic shut off.
Has anyone else noticed this problem with any Ford Focus 2008 onwards model and if so what's the problem ? My previous Focus 05 never had this problem.
kith (Thu 3 Sep 09 14:09):
I guess that this is the new "Easyfuel" system. A few of us Mk4 Mondeo owners have had this problem. In the Mondeo handbook it says you should leave the nozzle in the filler for 10 seconds after the fuel has stopped flowing.
I noticed that the spillage was occurring when I put the nozzle into the filler neck, before I started to pump fuel. I concluded from this that the fuel that was on the floor was residual fuel from the previous fill-up, where I had not waited the 10 seconds and it had been trapped somewhere up in the filler area. I now wait 10 seconds after the pump has clicked off on every fill and on the next fill there is no spillage.
P.s. It looks a lot on the floor, but it's not 0.5 Litres. ;0)
MikeTorque (Thu 3 Sep 09 23:43):
I found this information on how to put fuel in to a Ford Easy Fuel system, hopefully this will address the problem. I've already had the Easy Fuel system changed as it was faulty when I purchased the car so I've ruled that out. Hopefully it's user error, see below for further details.
The New Focus (12/2007-) spring-loaded tank flaps close off the upper end of the fuel tank filler pipe in place of the filler cap. The first spring-loaded tank flap features a locking mechanism which checks the filling station nozzle for the right size. This locking mechanism consists primarily of a slider and two releasing notches. The slider has the diameter matching the right filling station nozzle. When the correct filling station nozzle is inserted, the notches move inwards, releasing the slider which in return releases the spring-loaded first flap. Further insertion of the filling station nozzle opens the second flap which seals the tank against the environment.
The following steps for re-fuelling the fuel tank should be explained to the customer:
1. Insert the filling station nozzle so far that the first notch of the filling station nozzle can be hooked into the capless system cover. The filling station nozzle should not be inserted any further either. Likewise in case of filling the car at the roadside with a jerry-can the funnel needs to be inserted until the ring of the funnel rests behind the cover.
2. If the customer experiences difficulties at some filling stations it helps to drop the filling station nozzle until it rests on the fuel filler pipe cover.
- Re-fuel the fuel tank (automatic cut-off or manual handling)
- Do not change position of the fuel pump nozzle during refilling. The fuel flow will be interrupted prematurely.
It is recommended to refuel the fuel tank until the first automatic shut off of the filling station nozzle.
A further refuelling until the next automatic shut off could lead to fuel dripping from the fuel tank overflow pipe to the ground.
After fuelling the filling station nozzle should remain for 10 sec. to allow a remaining quantity of fuel to flow into the fuel tank. Otherwise this quantity of fuel will be drained via the fuel tank overflow pipe to the ground.
- Dzefer
Re: Palivova nadrz
no to som nevedel o tych 10 sekundach, ani o tom, ze nemam tankovat nakrivo
Mne to robilo iba ked som mal nove auto a dotankovaval som aj po prvom vypnuti. Potom som sa poucil, vsetko bolo ok, az pri poslednom to tieklo dokonca pocas tankovania, to som este nemal
Ale ok, vdaka za info, radsej si teda vzdy pockam na spravnu stranu stojana, aj ked podla zakonov schvalnosti su vzdy tie spravne strany obsadene
- madbugie
Re: Palivova nadrz
chuapi sak tam je aj taky obraztok ze ta hadica ma byt volne polozena...
tuk tuk tuk na drevo mne zatial chvalabohu nic netieklo aj pri tankovani doplna... ja tu pistol radsej vyberam pomalejsie a aj ju oklepkam aby mi to netieklo po kapote...
ono presne ako pise anglan kvapnite si kvapku benzinu a ona sa neskutocne rozlezie cize to vyzera ze toho vytieklo vela...
modrá je dobrá ale iba ako farba auta
+ 100 fordích koníkov
zirafak
Re: Palivova nadrz
je vidiet,ze v tom mas praxmadbugie píše:... ja tu pistol radsej vyberam pomalejsie a aj ju oklepkam aby mi to netieklo po kapote......
- Dzefer
Re: Palivova nadrz
madbugie: sak hadica bola volne polozena, len isla zvrchu, lebo som ju musel natiahnut okolo celeho auta
Ja oklepkavam tiez, nie som prasa
zirafak
Re: Palivova nadrz
Vy ste teda borci,lebo natiahnut hadicu okolo celeho auta
to je vykon
- Dzefer
- madbugie
Re: Palivova nadrz
nabuduce skus do druhej dierky
a uvidis...
ono to bude asi tym ze ta tankovacia hlavica samotna je zalomena a ked ju tam "pichnes" zvchu tak vlastne "strieka" trosku dohora
(aj ked na starom favorite mi to problem nerobilo... ono zasa to auto je o 20 centi uzsie tak to asi islo lahsie natahovat....)
a oklepkavat treba, to nevies...
PS: zirafak sak preto mam take pekne dve detusky
jo a teto poznas:
cura Jano s cernochom na WCku a pozera na tu jeho dlhu ruru... a pyta sa ho ze ako to robis ze ho mas taky dlhy... Cernoch na to to vies to musis mat spravnu techniku... rychlo dnu a pomaly vytahujes von a on sa ti casom predlzi... Jano skoci hned doma na Maru a spomenie si a tak to robi rychlo dnu a pomaly von... mara sa otoci, treskne mu jednu popapuli ze Fuj ty prasa jedno perverzne robis mi to ako cernoch...
jo a teto poznas:
sunrise77
palivová nádrž
Potreboval som odčerpať zo 3 dcl nafty z nádrže, a vopchal som do nej hadičku.Bohužial som si neuvedomil, že tam je pravdepodobne neaké sitko.Pri najbližšom tankovaní mi to došlo po tom, keď pri plnom stisnutí spúšte na hadici nafta nestačí stekať do nádrže a vytekala mi von.Potom som musel len pri malom tlaku liať dnu naftu. Pravdepodobne sa sitko ( alebo niečo iné ) porušilo a spriečilo sa mi v potrubí.Hnevá ma to, lebo viem že som si to sposobil sám s mojou blbostou..
Viete čo robiť ? dá sa tam neakým sposobom dostať ? rozobrať prívodné potrubie do nádrže a opraviť to? Inak budem čapovať na pumpe 2 hodiny.... som zúfalý
FF II 1,8 TDCI 85kw 2006
Naposledy upravil(a) sunrise77 dne 02.12.2009 21:16, celkem upraveno 1 x.
zirafak
Re: palivová nádrž
Na akom aute?
...A staci to zadat di iba jednej temy
sunrise77
Re: palivová nádrž
jj už som to opravil... vieš pomocť ??zirafak píše:Na akom aute?
Jirik600
Re: Palivova nadrz
V potrubí dole je klapka proti odčerpání paliva. Asi jsi ji při pokusech odčerpat palivo hadicí nějak vzpříčil a ona se neotvírá a proto propouští jen málo nafty.
FF2 1,6TDCI 66Kw 2007
- stand
Re: Palivova nadrz
zkusil bych hadici a šťouráním znova uvolnit:)
