Flat out 2-potíže
miggell
Re: Flat out 2-potíže
Příspěvek od miggell » 09.08.2008 12:01
no kazdopádne to može sposobovat ta grafika, pretože pozri čo som našiel na oficialnej stranke FO2
System Requirements
Windows Operating Systems: Windows XP (32bit) Windows Vista (32/64bit)
Processor: Intel Processor 2.2GHz or Higher / AMD 2.2GHz or Higher
System Memory: 2GB or higher.
Hard Drive Space: 4.75GB Free Hard Disk Space
Graphics Cards: DirectX 9.0c or higher supported graphics cards with 256MB of Memory.
Supported Cards:
Nvidia Geforce 7600 or higher.
ATI Radeon X1800 or higher.
Integrated Graphics Chips and Laptops are not supported by this game.
Soundcard: DirectX 9.0c supported Soundcard.
každopádne si vyskúšaj tento link a zvol Flatout2. otestuje ti to počítač,ako si na tom v tej konkretnej hre
http://www.systemrequirementslab.com/referrer/srtest
bol :Focus combi II Sport 2005 2.0 TDCI 154PS + Eibach Prokit
je:Renault Laguna GT Grandtour 2.0 dCi 180 PS
pppavel
Příspěvek od pppavel » 09.08.2008 18:28
Díky.Tak podle toho by to mělo makat.Celkový výsledek je dobrý ikdyž tam i něco je..u
Video Card Driver Version (DirectX-to nechápu...
CPU Speed
Minimum: 2 GHz
You Have: 2.01 GHz Performance Rated at 5.70 GHz PASS
System RAM
Minimum: 256 MB
You Have: 2.0 GB PASS
Operating System
Minimum: Windows 2000/XP
You Have: Microsoft Windows XP Professional (Build Service Pack 22600) PASS
Video Card
Minimum: 64MB video card (GeForce FX, Radeon X300)
You Have: NVIDIA GeForce 7300 GT (GeForce 7300 GT) PASS
Video Card Features - Minimum attributes of your Video Card Video RAM: Required - 64 MB , You have - 256 MB
Video Card 3D Acceleration: Required - Yes , You have - Yes
Video HW Transform & Lighting: Required - Yes , You have - Yes
Vertex Shader Ver.: Required - 2.0 , You have - 3.0
Pixel Shader Ver.: Required - 2.0 , You have - 3.0
Video Card Driver Version (DirectX)
Your driver version number is: 6.14.10.9381 FYI: Your video card driver version is provided for your information, but it is not part of this analysis. But proper video card driver versions are important to the proper operation of your product.
DirectX Version
Minimum: 9.0c
You Have: 9.0c PASS
Sound Card
Minimum: Yes
You Have: SoundMAX HD Audio PASS
Sound Card Driver Version
Your driver version number is: 1.0 FYI: Your sound card driver version is provided for your information, but it is not part of this analysis. But proper sound card driver versions are important to the proper operation of your product.
Free Disk Space
Minimum: 3.5 GB
You Have: 158.1 GB PASS
Ford focus 1.6 kombi,rv99,ghia,PC,vyhř.čelní sklo-tmavě modrá metalíza-aktuální spotřeba 6,9 l/100km
GALERIE- https://forum.ford-focus.cz/viewtopic.php?f=96&t=8925 -GALERIE
zewl
Příspěvek od zewl » 09.08.2008 19:10
na prehrivani grafiky zkus udelat maly test: otevri skrin pocitace, vem stolni ventilator, namir ho do skrine PC, idealne na grafiku zespodu (tam, kde jsou cipy) a zapni ho na plny vykon. Nyni zkus hru hrat (s otevrenou PC skrini a ventilatorem v provozu), zda se opet sekne :idea:
TripleJay
Příspěvek od TripleJay » 09.08.2008 22:57
Ja si dovolim nesuhlasit... Ak mas stock grafiku, to nehrozi ze by sa pri hocijakej hre prehrievala, pokial to nemas pretaktovane... To sa proste neda. Aj nova 4850 ma pri idle 85-90°, ale proste to nezamrzne, to neexist :| A problem by som skor videl v procaku, kde BOX chladic je riadna sracka. Grafiku so stock chladicom bez pretatovania neuvaris, ale procak s BOX chladicom, nebodaj aj ak v BIOS-e zmenis otacky dole kôli hluku, tak dovi dopo...
P.S: tiez nesuhlasim. dobre odvetrany pc s intake a outtake ventilatorom so spravne danym fanom CPU jre vzdy lepsi ako total otvorena debna, kde flow je kvazi nulovy
zewl
Příspěvek od zewl » 09.08.2008 23:09
TJ: je otazka, jestli ma v bedne pruvan, jak jsi to popsal. Proto jsem doporucil zkusit vetrak, ktery potom eliminuje vice veci, vcetne spatneho chlazeni CPU.
dobre odvetrany pc s intake a outtake ventilatorom so spravne danym fanom CPU jre vzdy lepsi ako total otvorena debna, kde flow je kvazi nulovy -> souhlas, ale tohle nevime :wink:
pppavel
Příspěvek od pppavel » 10.08.2008 08:16
mám obyč PC takže žádný extra větrák.Zkusím tedy sundat bok at' tam jde líp vzduch......
Charon
Příspěvek od Charon » 10.08.2008 20:40
Ježíšku na křížku :twisted: :twisted: :twisted:,
pokud se někomu špatně chladí cokoli uvnitř počítače, je třeba přidat další větrák (tažný do zadní pozice, tlačný do přední pozice). Pokud otevřete skříň dosáhnete jediného - zrušíte nucenou cirkulaci vzduchu uvnitř.
Kontrolní otázka - proč si myslíte že servery mají uzavřené skříně bez ozdůbek a různých dalších vývrtů, kabely úhledně ztažené pásky,... :?:
:idea: Znovu opakuji radu - zrušit běžící rezidenty a vyzkoušet funkci. :idea:
https://www.kpvt.cz
FoFoII - Brumla. Nějaký benzínový motor (asi čtyřválec - alespoň myslím), Ten delší typ.
Divná barva (ani modrá - ani stříbrná) - Tonic bez Fernetu
(II/1.6/74/6.9-9.5/C)
zewl
Příspěvek od zewl » 10.08.2008 21:15
Charon: pokud nema vetraky v komplu, ktery by teply vzduch odvadely, tak si stale myslim, ze nejlepsim testem, zda zamrzavani PC zpusobuje prehrivani nejake komponenty, je test, ktery jsem popsal :wink:
Samozrejme, ze z dlouhodobeho hlediska je mit otevrenou skrin a stolni ventilator do ni namiren na houby :wink:
Charon
Příspěvek od Charon » 11.08.2008 09:23
:idea: Pokud by byl problém s teplotami, nebo větráky :idea:
http://www.almico.com/sfdownload.php
Pokud si to v nastavení přepneš na češtinu ani nemusíš hledat co který údaj či záložka znamená. Mělo by to umět i logovat události - rozborem logu je většinou možno zjistit teploty před pádem.
https://www.kpvt.cz
pppavel
Příspěvek od pppavel » 11.08.2008 17:34
Tak v tom se nevyznám.Fakt je že žádný větrák navíc tam nemám... :cry:
